How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
I am having trouble figuring out how to open the canister of my Electro- and Aerus-Lux canister vacuum cleaners. They are designed to baffle DIYers. I have a hacksaw, and I am willing to use it.
I did a Google search using different terms and found some possible solutions which I will post as soon as I test them out.I did a Google search using different terms and found some possible solutions which I will post as soon as I test them out.
I tried to post the solution I found to this challenge, but I couldn't figure out how to post it. What I did post, I posted in the wrong place. I think I found it under Electrolux LE model 1623. I'll do my best here: 1. Unplug canister, remove hose and bag. 2. Open bag compartment and lay the canister on either side. Leave the bag compartment (front) open. 3. Use a block and hammer to knock the bumpers on either side toward the open bag compartment. 4. Place the block behind the bumper at the rear end of the canister, and give it a couple of good solid whacks. This frees the number assembly out of the little catch that holds it in place. Do the same on the other side, and there you have an open canister. Now all I have to do is figure out how to open the motor and fan housing! Any ideas?I tried to post the solution I found to this challenge, but I couldn't figure out how to post it. What I did post, I posted in the wrong place. I think I found it under Electrolux LE model 1623. I'll do my best here: 1. Unplug canister, remove hose and bag. 2. Open bag compartment and lay the canister on either side. Leave the bag compartment (front) open. 3. Use a block and hammer to knock the bumpers on either side toward the open bag compartment. 4. Place the block behind the bumper at the rear end of the canister, and give it a couple of good solid whacks. This frees the number assembly out of the little catch that holds it in place. Do the same on the other side, and there you have an open canister. Now all I have to do is figure out how to open the motor and fan housing! Any ideas?
You can't post conmments that contain an email address.
Re: How do you access the motor and guts of an Aeruslux...
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Hello, it sounds like you make have a wire loose in your canister. The canister needs to be repair by a qualified repair person due to shock hardzards.
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
Similar to your Kenmore upright is the canister. Here is a video clip by another with similar issue of trying to open the darn thing up. I hope this gets you closer to solving your problem with the vacuum. If not with a few Kenmore vacuum "search" in youtube I think you will find what you need.
PEACE https://www.youtube.com/watch?v=s0aaoPzCAcMKenmore 116 26212690 vacuum cleaner disassembly to motor
depending on the problem, it could be the thermostat this is next to the motor and if you are have trouble getting to the motor it has probably over heated and the plastic has melted together. as you can see the motor is in a small place and has a plastic case over the top the motor comes out through the top, hope this helps
