The 2002 motor not sqirting water out the motor anymore
Your question is rather ambiguous and does not have much detail about what you are seeing. Are you referring to the windshield washer fluid that is supposed to spray on the windshield when you select that function?
The only water that is supposed to be coming from the motor itself is burned hydrogen coming out of the tail pipe (water dripping from the pipe). If you have had water coming out of the engine or its hoses under the hood, and now you don't, you may have just lost a major share of your coolant to a leak, and risk damaging the engine by overheating it. When the engine is cold (never do this when it is hot!), remove the radiator cap and check to see if the coolant level is up to the top of the radiator. If it is not you may have a coolant leak. If so, get the leak repaired ASAP and add the coolant specified by the owner's manual.
Were you seeing the water under the car only when you ran the air conditioning? This is normal in humid weather, the chiller section of the air conditioning condenses water out of the air and drips it onto the ground; however if the air is very dry, any condensation evaporates off of the chiller instead of dripping. If you don't see any water dripping underneath the car when the A/C is running, and the weather is humid, either the A/C isn't working (the inside of the car stays hot), or the condensate drain is plugged up and should be cleaned to prevent corrosion problems.
