20 Most Recent Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Questions & Answers
2answers
I have a water dispenser that freeze the water
check control setting
11/19/2016 4:21:01 AM • Whynter FX-6SB... • Answered on Nov 19, 2016
2answers
MY HAMILTON BEACH WATER DISPENSER
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
2/1/2016 1:50:51 AM • Whynter FX-6SB... • Answered on Feb 01, 2016
8answers
Sunbeam cold and hot water dispenser
Try to find them here Find the low cost Wholesalers Dropshippers on biggest wholesale place. Best of luck
10/31/2014 4:06:00 PM • Whynter FX-6SB... • Answered on Oct 31, 2014
Please remove me from your deta base . Otherwise I will seek further . I did not give permission for your company to post my name. please remove right away!
Contact customer service and beg and plead. If that fails threaten and insult, crying sometimes adds the pity factor and if that fails log into your account and change all your data to false information! :-)
8/13/2014 5:05:54 PM • Whynter FX-6SB... • Answered on Aug 13, 2014
2answers
Water doesn't get hot
It is probably a faulty valve..
4/10/2014 12:42:17 AM • Whynter FX-6SB... • Answered on Apr 10, 2014
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
5/23/2011 5:47:06 PM • Whynter FX-6SB... • Answered on May 23, 2011
Cooler not running
Check power to relay. If yes, check compressor is working. If yes, keep your hand on discharge pipe. If it's not warm, cooler is under gas leak. Rectify leak and recharge gas.Thanks.
1/24/2011 4:38:39 PM • Whynter FX-6SB... • Answered on Jan 24, 2011
How do install the hot water handle for model
i have problems with hot water, the handle is broken
YLR2-%-24H2
12/30/2010 2:57:29 AM • Whynter FX-6SB... • Answered on Dec 30, 2010
2answers
Sunbeam Drinking Water Cooler model YLR2-5-24H2
my hot water faucet is broken!!.. when can i get new?
12/30/2010 2:42:11 AM • Whynter FX-6SB... • Answered on Dec 30, 2010
6answers
Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
water leak from inside the refrigerator
12/18/2010 5:26:54 PM • Whynter FX-6SB... • Answered on Dec 18, 2010
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ [email protected]
11/15/2010 9:51:43 PM • Whynter FX-6SB... • Answered on Nov 15, 2010
Need instruction booklet
Hi.
The only manual available is the one for the new 7SB series. The manual and the dispensers are practically the same. Please download the manual here: FX-7SB user manual
The manual for FX-6SB can only be obtained contacting Whynter: Phone: 866-WHYNTER Email:[email protected]
11/2/2010 11:05:45 AM • Whynter FX-6SB... • Answered on Nov 02, 2010
How do the parts go together in the water tank on
solution
6/21/2010 9:19:57 PM • Whynter FX-6SB... • Answered on Jun 21, 2010
I need all three handles red, white, and blue for
RUN THE MODEL NUMBER ON THE SEARS SITE. YOU MAY GET AN ILLISTRATED PARTS BREAK DOWN AND BE ABLE TO ORDER THE PARTS. http://www.searspartsdirect.com/partsdirect/index.action
4/24/2010 3:27:43 AM • Whynter FX-6SB... • Answered on Apr 24, 2010
I need to find replacement valves for my Sunbeam
Found a pair on eBay for about 23.00 shipped
1/7/2010 4:26:12 PM • Whynter FX-6SB... • Answered on Jan 07, 2010
The water doesnt get cold
check to see if the condenser on the refrigeration unit is clean and clear
9/5/2009 12:49:13 AM • Whynter FX-6SB... • Answered on Sep 05, 2009
WATER COOLER DOESN'T COOL THE WATER ENOUGH
clean coils check for temperature setting!
6/30/2009 8:12:20 PM • Whynter FX-6SB... • Answered on Jun 30, 2009
Need a handle for the hot water on a YLR-5-87H3 WATER DISPENSER
My water cooler was made for Sunbeam by Prestige Home Comfort of Canada. 1-877-383-6399 Mon thru Fri 8:30 am - 5:30 PM ET to order parts or [email protected] to contact
5/30/2009 1:42:27 PM • Whynter FX-6SB... • Answered on May 30, 2009
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
5/30/2009 1:32:44 PM • Whynter FX-6SB... • Answered on May 30, 2009
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
1/19/2009 5:33:47 PM • Whynter FX-6SB... • Answered on Jan 19, 2009
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
83 questions posted
Top Whynter Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Whynter Water Filters & Coolers
Most Popular Question
sunbeam cold hot water dispenser
  • Water Filters & Coolers
