Video Cameras Logo
A
Anonymous Posted on Jul 17, 2014
How to connect sony handycam to Samsung 40" LED TV
1 Related Answer
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on Feb 25, 2009
SOURCE: Cant record - error on display E:40:00
it is a typically seems like LENS problem lens got weak and unable to record have u changed recording media tried several dvd -rw or dvd-r what are the results , can u see the lens with ur eyes if yes u can clean it with very soft cloth used to clean lcd's see if it works , other wise buy a mini dvd cleaner with brush on it may be it helps in this situtation other wise the whole lens will be replaced but this is too much for that 170 , pls try the solutions and let me know ,, do try the lens cleaning thing it works in some cases
2answers
Seeking Owner's manual
have you looked in the owner's manual ?
Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
15.January.2016
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
1helpful
2answers
How to connect to tv
I don't know how to connect my sony dcr hc 21e with the tv can someone help me please.....
mogie naiken
6helpful
3answers
Video transfer from sony handycam ccd-trv 308 hi8 to a computer
I have a sony handycam ccd-trv 308 hi8 analog camcorder and I was trying to transfer videos from it to my computer. However, when I plug the S-video cable to the handycam and my computer, nothing happens. Does my computer require a driver to recognize the handycam because I cannot find any in the sites of sony for my handycam's model. Or am I using the wrong wire?
My LED screen got damaged, and I don't know how to finalize a mini disc in order to playback on computer and transfer to DVD. Can you tell me how to finalize the DVD-RW disc so I can play it back??
My LED is damaged too...don't know how it happened, but..if you hook your handycam to your TV - you can see the LED on the TV and know where to press on the LED to finalize.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
