Cars & Trucks Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sputtering then stopped running and wont turn over.
Ronaldbrains
Level 3:
  • Master 881 Answers
  • Posted on Sep 29, 2009
Ronaldbrains
Master
Level 3:
Answers
881
Questions
0
Helped
299505
Points
2375
Wont turn over are you sure as wont start is differant than wont run
Wont start could be Battery/starter/or engine siezed.
Wont run is not the same,,, that could be lacking power /low on oil/water/ Fuel/or even engine lacking power like down on compression which is all the above plus more ....
So check it out let us know again. Ron
Ford trader truck 1984 it wont turn off? have to stall it to stop it?
Is the truck really running or is it spitting and sputtering when turned off? The spitting and sputtering is called run on and is caused by carbon build up in the cylinders. With these older engines, they still have carburetors and will still provide gas to the engine if it's "running on" even with the ignition in the off position. Get some sea foam and foam the engine as the directions say. It will help remove some carbon deposits.
Sputtering on 1991 nissan maxima from a stop then at 2000 rpm or so it will run grat
its your idyll. You need to turn up the gas flow to the fuel injection or the carburetor.
1990 f150 302 v8 5.0 sputtered and died and now wont start. What could be the problem?
Turn the ignition switch to run, without starting it. You should hear the electric fuel pump, in the gas tank, run for about 3 to 4 seconds, until it builds to proper pressure. If it is not humming along it needs replaced.
murf427
02 Olds Bravada all wheel drive 6 cylinder. Starts but wont run. It sputters and then shuts off. It just started doing this. Wife came home yesterday and said the check engine light just cam on and the...
Check the plugs and see if they have fuel on them if not check the catalytic converter it could be plugged and putting back pressure on the engine and not allowing the fuel into the cylinders. Can you spray fuel into the throttle body and get it to run. If so you may have a fuel pump problem or fuel filter issue. I am betting on the cat. you can pull the o2 sensor ahead of the cat and the engine should run if it is plugged. It will run rough but at least it should start.
Cranks turns over...almost starts but sputters out...if i choke the throttle body it will run but barley
timing chain or gear common problem, my first one happened in a 1931 model a ford, have had many do that since, i just lost the timing chain in my 1988 ford van, barely runs, wont go....
Fuel problem with 03 alero.......Sputtered, died, now wont stop
I am having the same exact issue right now with my 01 Alero. Been having electrical issues with lights coming on and off. ABS was kicking on a few times even. It started sputtering like it was running out of gas, thought that might have been the case. But after I put gas in it it still didn't start. Now it turns over but nothing. What ended up being wrong with yours?
1helpful
Stopped running on the highway as i disengaged cruise
it sounds like ou may have a weak fuel pump. if all it does is sputter then its starved for fuel. you might also check for water in the tank if theres enough water built up it wont run right
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
