Oven door won't unlock
Hello Friend, thank you for allowing me to assist you!
I see that the door of your your Frigidaire range (GLES388ASD) will not unlock. Let's trying pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if you have a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is necessary to wait roughly ten minutes and then turn your range on.
I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck!
SOURCE: oven door cannot unlock
I know this response is a bit dated, but I just had the same problem. I removed the back panel. There is a little motor that turns the locking mechanism. I removed that and there is a button on a sensor next to the motor. I turned off the power first, since 220 can kill. Then when everything was sorted out, i turned the power back on, hit the switch on the sensor and everything is back to normal. I also made sure that the lock in front was back at 12 o'clock (the L shaped piece at the top of the door, but on the stove),. It worked for us. Good luck.
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
SOURCE: the oven door won't unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
SOURCE: MY self cleaning oven door will not unlock. Have tried to reset it. But it won't release
Hello.
What you need to do to solove the problem of the oven first of all carefull out off the oven from the power supply for some time then allow it to cool it self down for some time.
PLEASE note this dot not force the oven open after the first instruction above .
Then plug the oven back to the power click on the reset button,then after that you can then click on the open button and the problem is solve.
Thanks.
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
