The remote controller is broken [I'm sourcing a replacement] I pressed a button on the side [Looking at screen the right side] This changed it to DVD mode. How do I change it back to TV mode
You might have pressed the AV selector botton on the side panel of the TV. It works as a toggle type switch. Press on once will select the TV input, and for an other press will come back to AV and so on.
Locate that switch you have pressed earlier, and press it once more, to select the input to TV.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
Turn on your TV and make sure your DVD player is connected to it.
Look for the "Menu" button on the TV and press it.
Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
Press the "Enter" button to select the input/source option.
Use the arrow buttons to select the input/source that corresponds to your DVD player.
Press the "Enter" button to confirm the selection.
Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
On page v of the manual (if you had one), under the heading "DVD Mode", the first item in the list is an up-arrow symbol, with "Press to eject the disc" next to it.
That's simple enough, IF you have a user guide. But if you don't, and you weren't familiar with standard symbology for these types of buttons, you would be stumped by the moronic design of the remote control.
The up-arrow button is on the top row of the Remote Control buttons, next to the red Standby button. It's a standard Eject symbol, but not only did they just assume you'd know that, they obfuscated the situation further by marking it as "TV/Radio". So if you weren't familiar with the symbology, you certainly wouldn't be looking for something marked TV/Radio to eject a DVD.
But there's another catch: The up-arrow/eject button will only work if your Source is set to DVD. If for any reason you switched away from the DVD before wanting to eject it, you would find that the Eject button no longer works. You have to switch back to Source = DVD, then press the eject button.
IMO, there is no excuse for a Remote Control design that can't be figured out without the manual.
Changing Region Code on Oppo and Similar DVD Players
Press the "On" button on the remote control to turn on the DVD player.
Press the "Setup" button on the remote control.
Press the following buttons in this precise order: 9210.
Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
5
Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
Changing Region Code on Sony and Similar DVD Players
6
Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
7
Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
8
Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
9
Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
10
Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
Changing Region Code on Denon and Similar DVD Players
11
Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
12
13
14
15
Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
For RC-LRN Remote (5 digit coding)
Before starting, retreive the 5 digit codes for you device - I found all my codes at http://2getdtv.com/directv/remote_codes.html
1. Press button for the device you want to program ie DVD.
2. Press and hold Setup button until it blinks twice.
3. Enter 5 Digit Code (ie LG DVD =31531), the power button will blink once slowly
4. Then press power button to turn on/off device.
5. If code fails, try next code.
Note: Some codes work better than others. Source: http://www.fixya.com/support/t7582447-program
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
Hi, Try this 1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources?
Depending on the model TV you have, there are up to four ways to change the video source:
Through the on-screen menu controlled by your remote
Through the on-screen menu accessed through the Menu button on your TV's front panel
Through the TV/Video, TV/Component, or Source button on your remote
Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote
To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
Turn on your TV.
Press the Menu button on your remote. The Main Menu appears.
Select Input, and then press the Enter button. The Input menu appears.
Select Source List, and then press the Enter button.
Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV
To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
Turn on your TV.
Press the Menu button on the front of your TV. The Main Menu appears.
Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote
To use your remote to change the video source, follow these steps:
Turn on your TV.
Press the TV/Video or Source button. The current source appears on the TV screen.
Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV
To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
Turn on your TV.
Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off. Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE) Press the (SOURCE) button on the remote or momentarily press the POWER button on the left side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting: DISC does NOT Play Parental code is set lower than than allowed by the DVD mounted. Ensure the disk is mounted in the player with the correct orientation (shiny side up). The disk is warped. The player cannot play certain formats (see the beginning of this manual). The region code on the DVD does not match the player. Moisture condensation has occurred within the player. Leave the unit on and the disc access cover open and try again after about 30 minutes. The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came with your disc authoring equipment.
