The scooter is electronically operated. Certain parameters have
been factory-set. These settings are designed to allow comfortable and efficient use. These parameters cannot be changed. The standard version of your scooter was tested according to the strictest EMI requirements. Mobile telephones have no influence on the driving behaviour of the scooter.
FORGOT TO SCAN THE PCM I SEE.
check all fuses.?
not told
fails hot and cold engine or both
car must be in transmission DRIVE selected? right?
and foot off gas pedal (accelerator)_ rpm goes to 2000 or up to 6000 rpm . and or
so driving foot off the pedal and RPM goes too high
or in drive, I step on the throttle (gas) and RPM shoots way high
and Never leaves 1st gear. that is transmission failures.
in DRIVE.
if rpm also goes that high right foot doing nothing and in park
that is engine idle control's failing.
we can not see you drive or how. so answers can be a tad hard.
in what gear? PRNDL (choices)
right foot doing what?
and what SPEED is too slow 20 or 85mph? or?
does tranny fail to upshift?
Batteries for Fortress 1700 DT Shipped from Canada - Batterybuyer.com. ... This purchase is for Two units of 12V 55AH Maintanence free rechargeable sealed lead acid ... [More] ... Fortress 1700 dt (4 wheel) u1 agm mobility scooter battery ... Best prices on: Power tool batteries, Cellphone, Tablets and numerous other hard ...
dirty or bad idle air control valve i would at worst the egr valve but most likely the idle air control valve which controls the air and idle from the throttle body try taking it out and cleaning the tip as well as in the throttle body where the control valve goes in if that dosent work replace it and the check engine light does not have to be on for it to be bad.good luck to you.
low speed activation of abs[will not set off code ] can also do brake studder without touching brake usually does it under 5 mph the problem is one of the sensors is dirty or has some corrosion on it ===chevy back in 2000 did a partial recall on the tahoe for the same problem the fix was to remove the sensor and clean it if the corrosion was to bad than sensor was replaced === the problem with no code is u dont know which sensor is causing problem u would need to remove both and check them
