Garden Logo
A
Anonymous Posted on Jul 11, 2014
Who makes Stanley pressure washer motors - Stanley Garden
Stanley P1800S pressure washer lost pressure after a few uses
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
Stanley electric pressure washer makes a grinding noise after 6 or 7 min and looses pressure and flow
It sounds to me that there is air in the pump, remove the nozzle if possible and pull trigger until the air works thru the pump.
2answers
Motor switch replacement Stanley model#swk-PAC 150h air compressor
For safety reasons work on mains voltage switches must be preformed by a qualified electrician.
2helpful
Stanley motorised pressure washer. Cant get the water to flow
Disconnect the wand from the washer if you get water coming out of the discharge, the problem is in your wand or the line is plugged going to the wand.
Stanley instruction manual
There is a spring in there that makes it recoil. It has probably broken. Depending on who made the engine you can get a replacement for the whole assembly. A small engine shop should be able to replace it for a not a lot of money.
I own a stanley pressure washer and it keeps tripping out
The pump will cycle on/off but if it works properly when you pull the trigger and it keeps working then its working correctly.
Pump won't run
Did you figure this out yet? If not.
Did you check the onboard GFI breaker switch?
Did you make sure the water was connected and turned on?
Leakage from the garden hose connection along with connection to the pressure washer.
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
