20 Most Recent Stanley 1600PSI Pressure Washer w 20ft Hose Accessories Questions & Answers
WHATDO I DO
Stanley 1600PSI... | Answered on Sep 20, 2012
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Stanley 1600PSI... | Answered on Jul 05, 2010
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Stanley Garden | Answered on Jun 14, 2019
Is tranny and various speeds working properly? How about the throttle control? Do you have it set for higher speed?
Stanley Garden | Answered on Aug 25, 2017
Try tilting the machine backwards for a few hours. It may be oil on the piston that is causing a vaccum
Stanley Garden | Answered on May 05, 2017
Stanley 1600PSI Pressure Washer w 20ft Hose  Accessories Logo
Popular Tags
9 questions posted
Top Stanley Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Andrew Taylor
Andrew Taylor
Are you a Stanley Garden Expert? Answer questions, earn points and help others
View Most Popular
Stanley Garden
  • Stanley Garden
Most Popular Question
reset button test button will
  • Garden
