hi there ibharti sounds like gx 160 honda ohv engine
replace the air filter if it has been wet with oil, , remove the float bowl and check for oil in the carb, blow the jets out, top up the oil to the point on the oil filler so that it just spills over when the threads start for the screw in cap ( from memory units only hold 600 or 700 mil of oil
use a 10w/40 or 20w/50 ) as honda have a problem with 30 wheight oil in respect to oil level shutdown sensors ( oil thins out too much ) and switch float does not float
if all is good in carby , remove plug and check oil has not got into combustion chamber
blow out with air if need to , refit plug , reassemble
let er rip , with water connected to pump of course or seals will burn from dry run
note unit may blow blue white smoke for a little while clearing itself , then settle back
in the mean time here is web site for parts if need
www.partstree.com
go to honda brand ,
or
www.ereplacementparts.com
cheers pauly46
