SOURCE: how do you reset a
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
SOURCE: Power went out at house....
yes it could be... but try to unplug the unit for 30 min. after 30 min try to plug again and turn on. check if the problem is solve. if not and if its under warranty just bring it back to the store or in the authorized service center. because there is no serviceable parts inside the unit... ty
SOURCE: where do i get a subwoofer that will connect to my rx-v371
you can connect Yamaha YST SW800 at the back of your receiver
( label =subwoofer )
http://uk.yamaha.com/en/products/audio-visual/speaker-systems/subwoofers/yst-sw800_black__u/?mode=model
SOURCE: How do you reset the
THE ANSWER (TO MINE AT LEAST) IS HERE:
As a safety precaution, when the protection circuitry operates 3 times consequently, the capability to turn on the power is disabled.
Solution (according to Yamaha service):
Plug the power cord out. Plug it back in.
Press the following three buttons at the same time for 5 seconds: Main Zone + Info + Tone Control
The receiver will open.
