20 Most Recent Yamaha RX-V371 5.1 Channel AV Receiver with Two HDMI Cables Questions & Answers
Where do i get a subwoofer that will connect to my rx-v371
you can connect Yamaha YST SW800 at the back of your receiver ( label =subwoofer )http://uk.yamaha.com/en/products/audio-visual/speaker-systems/subwoofers/yst-sw800_black__u/?mode=model
9/6/2012 4:16:47 AM • Yamaha RX-V371... • Answered on Sep 06, 2012
Can I connect my computer subwoofer to my Yamaha A/V receiver
Yes if it has a suitable speaker connection available and is nominally 8 ohms impedance Speaker and AV.
4/15/2024 11:25:42 PM • Yamaha Audio... • Answered on Apr 15, 2024
Yamaha M-60 Power Amplifier distortion and sound goes off sometimes
Being from 1985 or there abouts, it probably needs some TLC at a Yamaha service centre. May need new capacitors and resolder dry joints for age related issues.
4/1/2024 7:26:20 AM • Yamaha Audio... • Answered on Apr 01, 2024
Jerky sound in one channel Yamaha M-60 Power Amplifier
WD-40 ... Very dangerous as it not only flammable when wet but is bad for electrical contacts as it leaves a residue behind that does not conduct electricity very well. Check speaker connections first.
4/1/2024 7:22:45 AM • Yamaha Audio... • Answered on Apr 01, 2024
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool. the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny). ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
3/5/2024 10:05:15 PM • Yamaha Audio... • Answered on Mar 05, 2024
RX-V6A - Zone 2 Speakers do not give sound
Follow the procedure as given in following link. RX-V6A ' ENJOYING IN MULTIPLE ROOMS (ZONES) (yamaha.com)
12/14/2023 12:29:06 PM • Yamaha Audio... • Answered on Dec 14, 2023
Yamaha YST-FSW050 Ultra-compact powered subwoofer. It has bad vibration between 30-50 hz?
Question edited for clarity, full make model (what it is)'. Question moved to Yamaha Audio. It may be sympathetic vibration and is coming from something nearby. Put it on a folded towel or sit in the floor to test it. https://www.google.com/search?q=YST-FSW050+bad+vibration ..
12/9/2023 7:36:22 PM • Yamaha Audio... • Answered on Dec 09, 2023
How do I reset YAMAHA RX-V6A protection mode?
You must repair the amplifier first. Take it to an authorised Yamaha service centre.
12/6/2023 5:49:26 PM • Yamaha Audio... • Answered on Dec 06, 2023
Yamaha HTR-5750/5740. My Subwoofer not broadcasting
Visit 00_HTR-5750_U_EN.book (yamaha.com) and see page 59 (Troubleshooting).
9/23/2023 11:27:47 AM • Yamaha Audio... • Answered on Sep 23, 2023
No sound from Yamaha P155 Keyboard
9/19/2023 12:21:01 PM • Yamaha Audio... • Answered on Sep 19, 2023
How do I connect a SpeakerCraft BB275 to a Yamaha 5.1 receiver?
You can't do this. The SpeakerCraft is a standalone amplifier. The Yamaha is a Receiver and has its own amplifier. Putting amplified sound into a data input is not recommended and will cause component damage and overload 'clipping'. https://www.google.com/search?q=SpeakerCraft+BB275 https://www.google.com/search?q=Yamaha+5.1+receiver I deleted the two answers from AI Answer Bots as they are not doing you any favours suggesting it can be done in their waffling answers! ..
8/26/2023 12:13:06 AM • Yamaha Audio... • Answered on Aug 26, 2023
To fix or replace? My Yamaha RX-V663BL 7.1 Channel AV Receiver bought in 2009
Thanks for the compliments Gilbert. You have tried the reset so a Yamaha audio tech is the answer. This link will find you one close to where you live. There is probably a glass fuse on the power board, but you have to find out WHY the fuse blew? It is worth fixing in my opinion. https://www.google.com/search?q=yamaha+audio+repairs+near+me It does have a thermal fuse https://www.google.com/search?q=yamaha+rx-v663bl+no+power+on ..
8/22/2023 3:48:09 AM • Yamaha Audio... • Answered on Aug 22, 2023
KEF T301 Satellite Speakers. I can't get these to work is there a secret to these wall mount speakers?
Question edited for clarity and all the typos. The Yamaha receiver has to have a sound source and the speaker wires connect the two together. Receivers often have a a switch for Speaker set 1 and Speaker set 2, so you can send the music to two different rooms. Make sure you are on the correct set. These are supposed to be standalone television speakers by the looks of it connected to what they call an 'AV Processing Unit', I would guess more commonly called a Surround Sound Theatre System. Expensive speakers at $900. https://assets.kef.com/uploads/files/en/series_pdf/T301_T301c.pdf https://www.google.com/search?q=kef+t301+no+sound+from+speakers https://www.google.com/search?q=kef+t301 ..
8/22/2023 2:09:06 AM • Yamaha Audio... • Answered on Aug 22, 2023
Yamaha HTR-5660 6-Channel Digital Home Theater. How to reset this Yamaha receiver please?
Question edited for clarity. see if the video for the 5640 works. https://www.google.com/search?q=Yamaha+HTR-5660+reset ..
8/20/2023 3:34:10 AM • Yamaha Audio... • Answered on Aug 20, 2023
I have a Yamaha RX-v1800 amplifier. Need help connecting a Bluetooth music receiver
To connect the Bluetooth music receiver to your Yamaha RX-V1800 amplifier, you will need to use one of the available input options on the amplifier. The Yamaha RX-V1800 should have various audio input ports, and the specific connection method will depend on the output options provided by your Bluetooth music receiver. Here are the general steps to connect the receiver:
  1. Identify the audio output options of the Bluetooth music receiver: Check the output ports of the Bluetooth receiver and determine what type of connection it supports. Common output options include:
    • 3.5mm headphone jack (analog)
    • RCA (analog)
    • Optical (digital)
  2. Choose the corresponding input on the Yamaha RX-V1800: Depending on the output options of the Bluetooth music receiver, you need to select the appropriate input on the amplifier. The Yamaha RX-V1800 should have various input options, such as:
    • AUX (usually a 3.5mm stereo input)
    • CD (analog RCA input)
    • DVD/BD (analog RCA input)
    • OPTICAL (digital optical input)
  3. Connect the Bluetooth music receiver to the amplifier: Use the appropriate cable or adapter to connect the output of the Bluetooth music receiver to the selected input on the Yamaha RX-V1800. Here's how to do it based on the different output and input options:a. If the Bluetooth receiver has a 3.5mm headphone jack (analog output) and the Yamaha amplifier has an AUX input (3.5mm stereo input), use a 3.5mm to 3.5mm audio cable to connect them. b. If the Bluetooth receiver has RCA outputs (analog) and the Yamaha amplifier has corresponding RCA inputs (CD or DVD/BD), use an RCA cable (red and white connectors) to connect them. c. If the Bluetooth receiver has a digital optical output and the Yamaha amplifier has an optical input, use a digital optical cable to connect them.
  4. Set the input source on the amplifier: Once the Bluetooth receiver is physically connected to the amplifier, you'll need to select the corresponding input source on the Yamaha RX-V1800. Use the amplifier's remote control or front panel to select the input source you connected the Bluetooth receiver to (e.g., AUX, CD, DVD, OPTICAL, etc.).
  5. Pair and play: Turn on the Bluetooth function on your iPhone, put the Bluetooth receiver into pairing mode, and pair it with your iPhone. Once paired, you should be able to play your music from the iPhone, and the audio will be transmitted to the Yamaha RX-V1800 amplifier for playback.
Please note that the specific labels of the inputs on your Yamaha RX-V1800 might differ slightly from what I've mentioned, but the general concept of connecting the Bluetooth music receiver remains the same. Always refer to your amplifier's user manual for the exact location and naming of the input ports.
7/22/2023 7:03:17 PM • Yamaha Audio... • Answered on Jul 22, 2023
Bose P38. How do you hook up to Yamaha receiver.
It looks like the P38 is the powered Sub Woofer to the Lifestyle 38 system.
Bose LIFESTYLE 38 Operating Manual
ManualsLib https://www.manualslib.com > ... > Lifestyle 38 View and Download Bose LIFESTYLE 38 operating manual online. DVD Home entertainment system. LIFESTYLE 38 home theater system pdf manual download. Missing: P38 ‎' Must include: P38
7/19/2023 4:26:28 AM • Yamaha Audio... • Answered on Jul 19, 2023
Ysp1 Yamaha surround sound pops and shuts off about 15 minutes after it warms up. Any ideas?
If your Yamaha YSP1 surround sound system pops and shuts off approximately 15 minutes after it warms up, it could be indicative of an underlying issue. Here are a few potential causes and troubleshooting steps to consider:
  1. Overheating: One possibility is that the system is overheating, triggering a safety mechanism that shuts it down to prevent damage. Ensure that the ventilation around the unit is not obstructed. Check if the cooling fans are working properly and if any dust or debris has accumulated on them. If necessary, clean the fans and the system's vents to improve airflow and reduce the risk of overheating.
  2. Speaker Wiring or Connections: Faulty or loose speaker wiring or connections can cause intermittent issues and trigger the system to shut off. Double-check all speaker connections to ensure they are secure and properly connected. Inspect the wiring for any damage or shorts. Consider reseating the connections or replacing the wiring if necessary.
  3. Power Supply Problems: Issues with the power supply can also lead to shutdowns. Make sure the power cable is securely connected and not damaged. Try plugging the system into a different power outlet to eliminate the possibility of a faulty outlet causing the problem.
  4. Internal Component Fault: There may be a fault with an internal component, such as a capacitor or a power supply unit. This type of issue typically requires professional repair or component replacement. Contact Yamaha's customer support or consult a qualified technician for further diagnosis and assistance.
  5. Software or Firmware Updates: Check if there are any available software or firmware updates for your Yamaha YSP1 surround sound system. Sometimes, updating the system's software can resolve glitches or bugs that may be causing the shutdown issue.
If the troubleshooting steps do not resolve the problem, it's best to contact Yamaha's customer support or seek assistance from a qualified technician. They can provide specific guidance based on the model and help diagnose and address the underlying issue with your surround sound system.
7/15/2023 1:37:52 PM • Yamaha Audio... • Answered on Jul 15, 2023
Yamaha RX-V371 5.1 Channel AV Receiver with Two HDMI Cables Logo
Popular Tags
2 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
get subwoofer will connect rx v371
  • Audio Players & Recorders
