You will need a wire stripper, solder, solder flux, heat shrink tubing, a heat gun (hair dryer will do) and a soldering iron.
1. Cut the cord where the chip is.
2. Strip the wire on both sides by about 1/8". You should have 4 exposed wires from the two wires inside the cord.
3. Apply some soldering flux to the exposed end.
4. Heat the exposed wires and apply solder. This is call tinning and will help when you are attaching the wires.
5. Cut the heat shrink tube about 1/2" long, you will need two. Insert the heat shrink tube to both wires that is to be soldered.
6. Solder the wires together by applying heat and attaching the wires when the solder melt.
7. move the heat shrink over the soldered area and use a heat gun to heat the tube. It will shrink and provide insulation as well.
**If you don't have soldering experience, you might want to take it to an experienced technician. Bad solder or poor insulation can cause expose wires and poses an electric shock hazard!
Get online
and got to www.google.com In the google search box type: "Foxconn
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals on the site.
When you plug in the power cord is there any lights
whatsoever on the laptop, where the plug goes in or on the AC Adapter of the
power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the laptop is trying to boot or may have booted, but
the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever
when you press the power button. And if that's true maybe you was
operating off the battery the last time you had it on and since the power cord
is bad, it was not charging the battery so the battery is drained and the power
cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the
Battery, then Press and Hold the power button for 30
seconds. After 30 seconds plug the power cord back in (leave the battery
out) and hit the power button to see if it boots. If it does, you can put
the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the
memory chips. Set the chip aside then try rebooting the computer.
If it boots, then you know the memory chip you set aside is bad so mark an x on
it with an ink pen. If it fails to boot then move the chip to the next
memory slot and try rebooting. If it fails take the chip out and set it
aside, then put the other chip in and try booting it in both slots. If it
boots, just to verify that the chip set aside is bad, mark an x on it and put
it into the open memory chip slot and try booting.
power cord?
cord is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of the
