SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me:
Our KitchenAid KUDP series dishwasher went into a mode where it would
not start and would only respond to the cancel/drain button. The clean
light would flash 7 times in a row, stop, and then repeat. I read that
the 7 flashes indicates an error code and that the dishwasher has
detected a problem in the heater element circuit. I tried to reset the
error mode by turning off power for 15 minutes, however, that did not
work.
We
called for a repair. The service person found that the dishwasher was
completely fine except that it had gone into an error mode. The
technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We
were told the dishwasher expects to see the dish water temperature rise
in a certain way. If the water does not heat in this way, the
dishwasher becomes confused and thinks the heater element has failed.
In deed, this happened just following and extended power failure and
our hot water tank was cool. I am curious if this code will work for
anybody else with the same problem and save a service call and 115
bucks. Overall, this seems to be a serious logic flaw in the design.
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
SOURCE: KUDI01TJWH0 kitchen aid....the clean light is
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water
shut-off valve (located under the sink) is open. If you get water to
the dishwasher, but there is still no water inside during the fill
cycle, the problem might be with a faulty water valve (located at
the bottom of the dishwasher, behind the kick panel, on either
side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This
could be caused by a partially closed water shut-off valve (located
under the sink), or a faulty dishwasher water valve (located at the
bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher.
Make sure there is no debris blocking the holes inside each spray
arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees
Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to
both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the
dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
There are a few out there.
