It is unfortunate that the LCD screen has blurred. There is a possibility that the LCD screen has failed. You may want to use the below link and performing an LCD BIST:
http://dell.to/1irqbYp
Also try connecting a known good external monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
SOURCE: Dell Latitude D620 - Screen shows boot up, but then goes blank
Here are some easy things that can sometimes resolve this
problem:
1) Sometimes there can be a static buildup on the mother board. Power
off, remove the battery, remove the power cord and hold the power button in the
on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive
and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Hope this helps and have a super day!
Ron
SOURCE: Dell Latitude D620 Full System Recovery?
It's easy to miss the point at which you hit Ctrl + F11. You need to hit Ctrl + F11 at the point you see the blue bar across the top of the screen, it will display www.dell.com. If this is still not working you can use the XP operating system CD to reinstall XP and the Dell drivers CD to reinstall the sound, video, network and other drivers. If Dell didn't send you the operating system CD, you should contact them.
SOURCE: dell latiidue D620 beep codes
Manual:
http://support.dell.com/support/edocs/systems/latd620/en/index.htm
Hope this helps!
SOURCE: how do i unlock my dell latitude d620 notebook
I get this tutorial http://www.windowspasswordsrecovery.com/articles/password/dell-latitude-password-reset.html
to help me unlock my Dell Latitude admin password at ease!
SOURCE: Forgot Admin Password for Dell Latitude D620
when i got my Dell Windows 7 admin password, I follow video tutorial to reset password easily:
http://www.youtube.com/watch?v=IDIyKd8dNrQ
