20 Most Recent Dell Latitude D400 Notebook Questions & Answers
How restore a D400 to factory setting
Reboot the system and before Windows loads press the F12 key to get a boot menu. Choose the restore option. If that is corrupt or missing, try this: http://www.ehow.com/how_6547558_restore-dell-latitude-factory-settings.html
9/7/2014 10:18:24 PM • Dell Latitude... • Answered on Sep 07, 2014
How do i reset password for a dell lattitude d400
use usb bootable konboot to bypass user login then create admin account and delete existing one :)
8/6/2014 11:35:05 AM • Dell Latitude... • Answered on Aug 06, 2014
How to tacke my aspire 5250 back to factory settings
*******All of your data WILL be lost during this process so back everything up first********** 1. Power on the machine. 2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts. 3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.). 4. Click "OK" to continue. 5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes). 6. Once eRecovery has run, press "OK" to reboot unit. OR 1. Reboot, and press F8. 2. Select Repair. 3. Select Reinstall Windows and follow prompts. OR Running System Recovery from Windows 1. Click Start>All Programs>Acer Empowering Technology. 2. Select Acer eRecovery Management. 3. Select Restore (bottom of eRecovery screen). 4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.). 5. Select Yes then Next, the system will reboot and start the recovery.
7/5/2014 6:35:34 PM • Dell Latitude... • Answered on Jul 05, 2014
I have a dell latitude d400 laptop and I plugged
Hi Steven, Fn and F8 are the keys to press to cycle through LCD only, LCD and monitor, Monitor only. Pressing them again takes you back to LCD only. Many thanks, Jon.
7/2/2014 9:59:24 PM • Dell Latitude... • Answered on Jul 02, 2014
Yes I have a dell latitude d400 and I hooked up a
hold down Fn key and press F8 do it 3 times slowly til you see it on the monitor
5/3/2014 12:40:28 AM • Dell Latitude... • Answered on May 03, 2014
D400 is not booting up from usb
Is your system set up to boot from USB? What is attached? A flash drive or an external cd/dvd drive? If a flash drive, was the software on it created to be bootable? Is this the first time you are trying to boot from USB? Please provide more details.
3/1/2014 5:05:11 PM • Dell Latitude... • Answered on Mar 01, 2014
Factory restore
Luis, The Latitude D400 never shipped with a Factory Restore Image. You will need to format and reinstall Windows Manually. At the link below are instructions for reinstalling Windows on your system. Manually Reinstall Windows XPhttp://dell.to/1dLIxBqThank You,Dell-Jesse LDell Social Media and Communities
9/26/2013 2:08:00 PM • Dell Latitude... • Answered on Sep 26, 2013
0answers
Symantec antivirus install
OK, What is the question?
6/6/2013 10:49:49 PM • Dell Latitude... • Answered on Jun 06, 2013
The keyboard will not work and the 9 with a padlock light is on how do i fix this
Go to support.dell.com.
3/15/2013 4:29:50 AM • Dell Latitude... • Answered on Mar 15, 2013
Do not apear the speakers icon
jmcabcd,To Display The Volume IconBy default, the Volume icon is not displayed when you initially install Windows XP on your system.To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
If needed you may need to reinstall the sound drivers back into the system.You can download the drivers for your system by clicking the link below.Latitude D400 Sound Drivershttp://www.dell.com/support/drivers/us/en/19/Product/latitude-d400Thank You,Dell-Jesse LDell Social Media and Communities
2/12/2013 1:37:19 PM • Dell Latitude... • Answered on Feb 12, 2013
Power supply shorted will not start with new power supply
How do you know that it shorted? Where did it short? Is this an OEM DELL replacement power supply?
2/2/2013 12:16:20 AM • Dell Latitude... • Answered on Feb 02, 2013
Wont start in safe mode
Unplug, remove battery, plug in, reboot, tap repeatedly the F-8
1/20/2013 3:26:53 PM • Dell Latitude... • Answered on Jan 20, 2013
Master reset
If you mean Factory Recovery? Does your laptop have a Recovery Partition? Take a look at Dell support: http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=restore+dell+d400+to+factory&cat=all
12/29/2012 8:47:09 PM • Dell Latitude... • Answered on Dec 29, 2012
2answers
On a D400 how do you by pass the administrative password if you have no disc
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
10/18/2012 4:59:06 PM • Dell Latitude... • Answered on Oct 18, 2012
I forgot the bios password
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options MenuPlease select an option:
Safe ModeSafe Mode with NetworkingSafe Mode with Command Prompt
Enable Boot LoggingEnable VGA modeLast Known Good Configuration (your most recent settings that worked)Directory Services Restore Mode (Windows domain controllers only)Debugging Mode
Start Windows NormallyRebootReturn to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt
Then type at the C:\> prompt: typeDEBUG and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type: o 70 2e which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type: o 71 ff and hit Enter. Finally type: Q and hit Enter one last time to quit DEBUG back to the C:\> prompt. Now you're ready to reboot your PC, and press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup.
Youll notice the password is gone.
if this fails try typing
At command prompt type debug you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)A <ENTER>MOV AX,0 <ENTER>MOV AX,CX <ENTER>OUT 70,AL <ENTER>MOV AX,0 <ENTER>OUT 71,AL <ENTER>INC CX <ENTER>CMP CX,100 <ENTER>JB 103 <ENTER>INT 20 <ENTER><ENTER> just hit enter on this lineG <ENTER>Q <ENTER> Basic BIOS password - works 9.9 times out of ten
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
hope this helps
10/10/2012 3:31:23 AM • Dell Latitude... • Answered on Oct 10, 2012
Set back to factory settings
There is no such thing as factory settings, it is not a cell phone. The only thing you can do is restore settings to earlier time.
10/3/2012 5:09:31 PM • Dell Latitude... • Answered on Oct 03, 2012
Dell Latitude D400 Notebook Logo
128 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
not apear speakers icon
  • Computers & Internet
