What causes water to drip from air conditioning outlet on Astra 1.4 energy when air conditioning is not in use ?
When the A/C is not in use there is still condensation as your compressor will run at different times. Defrost is one, of course to cool the car is another. The condesation coming from that drain should be perfectly normal. My GMC Suburban drains all the time as well, and its usually because I leave my knob on the defrost setting even though the fan itself is off the compressor will still run as its hardwired to do so. If the compressor runs, the coil in your car will become cold resulting in the water you see. Hope this helps, thanks!
When the A/C is not in use there is still condensation as your compressor will run at different times. Defrost is one, of course to cool the car is another. The condensation coming from that drain should be perfectly normal. My GMC Suburban drains all the time as well, and its usually because I leave my knob on the defrost setting even though the fan itself is off the compressor will still run as its hardwired to do so. If the compressor runs, the coil in your car will become cold resulting in the water you see. Hope this helps, thanks!
