Shuts down for no reason then comes back on when driving then comes back on. What is causing this, it doesn't do it all of the time.
SOURCE: does anyone knows where to conect the dimmer wire
Connect to the side light live. So when you turn the lights on it dims the display.
SOURCE: how can put background on my kvt-514
1. Plug a USB drive with the picture(s) you want on the KVT-514 into the USB input.
- If there is any music or videos on the usb drive, the USB function of the player will try to take over. If this happens, change the function to something else (DVD or FM radio, etc... anything EXCEPT USB)
2. Go into Setup (is bottom button on main screen on US versions)
3. Select "User Interface"
4. on the first page, there should be some background options. The first is the current background (and a way to change to any loaded picture). The second is what you need to pay attention to. There is an "Eject" symbol Button and a "Memory" button. Select "Memory"
- It may take a little while, as it will read the USB device. Be patient.
5. After it reads the USB drive, it will display the contents as a external drive (it displays files, folders, etc.). Folders with files that the radio recognizes (pictures, music, videos, etc) will be highlighted in a bright white text while folders not containing them will be grey. Select the folder that the file is in and then the file. Alternately, if the file is in the root (not in a folder), just select the file. The transfer may take a while, be patient.
Hope this helps you.
SOURCE: i just got a kenwood kvt-512 and when plugging my
Hi...
usually these types of gadgets are blocked by the anti-virus or firewalls... So disable anti-virus program and any personal firewalls if any.... and connect the again,,.,..
And also ensure that the USB cable as well as usb port is working well.. also enable synchronization from your gadget...
Hope this has helped you...
Thanks...
SOURCE: kenwood kvt 514 can't turn on the sub
in the main option menu for choosing tuner dvd video etc. scroll down one and youll see "standby" put that on then scroll through the options and turn on the sub
