AT&T 1717 Digital Answering Machine Logo
A
Anonymous Posted on Jun 18, 2014
How to record message - AT&T 1717 Digital Answering Machine
4helpful
I need a user manual for a Cable and Wireless CWT2100 answerphone, Thanks Anne
I have the same phone. To record a message, press Menu - press down arrow keys until you get to Record Outgoing Message - Press and hold down Menu again to Record. You record handsfree. I have a problem with the quality of the recorded message, it is very hard to hear it, there is a lot of background noise.
If you want to revert back to the pre-recorded message, do all of the above as far as recording the message but instead of actually recording a message, lift the handset and it reinstates the pre-recorded message.
To listen to the message you have recorded, Press Menu, click on down arrow keys as far as OGM and press Menu again to play the message.
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
3helpful
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
1helpful
Change voice mail message
Step 1 Compose your message ahead of time. If not, you may end up stumbling, looking for the right words while you are recording your message or leaving out some important details. Composing your message before you begin recording will save you from having to record several messages before you find one with which you are satisfied.
  • Step 2 Make it easy for your callers to listen your message. Record your message in a relatively quiet room without background noise. Speak loudly and clearly. For the benefit of callers who don't have much time, make your message as brief and to the point as possible.
  • Step 3 Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 4 Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 5 Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 6 Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 7 Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 8 Press "Annc" if you want to listen to your message again
  • 0helpful
    How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
    Greeting message
    are greeted by a greeting message. You
    can record your own greeting message
    or use a prerecorded greeting
    message.
    message
    message (max. 2 minutes and 30
    seconds). If you do not record a
    greeting message, a prerecorded
    greeting message is used.
    1 {MENU}
    2 {V}/{^}: “Answering device” i
    {OK}
    3 {V}/{^}: “Record greeting” i
    {OK}
    4 After the handset beeps, speak
    from the microphone.
    5 To stop recording, press {OK}.
    6 {OFF}
    Using a prerecorded greeting
    message
    prerecorded greeting message for
    callers and ask them to leave
    messages.
    I can't remember how to record my outgoing message ?
    here you go...
    message
    1 {MENU}
    2 {V}/{^}: “Answering devicei
    {OK}
    3 {V}/{^}: “Record greetingi
    {OK}
    6 {OFF}
    If this helps you solve it, plz rate this fixya. Thank you kindly.
    1726 does not record messages
    System will not record messages
    When memory is full, saved messages must be deleted before new messages can be recorded.
    If RO (announce only) is selected, no messages will be recorded.
    2helpful
    The pre recorded message on the answering machine has been lost.
    I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
    message
    http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
    5helpful
    How do I record my own message for the answering machine?
    1. Press and hold down the announce button.
    2. You will hear record announcement after the tone.
    3. Once you hear record announcement after the tone continue holding the relase button and record your message.
    4. When you are done recording release the release button.
    5. To hear your recorded message press and hold the release button and release after you have heard your message.
    6. If you are not pleased with your recorded message, repeat the steps obove.
    Top AT&T Lands Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
