SOURCE: Hi I have a problem with RAM memory korg pa 800 in
If it says there is a RAM memory error, there is likely a bad module. If you installed these yourself, it is likely you have installed the wrong type or an incompatible configuration of the modules.
USUALLY the modules need to be identical in these synths. When upgrading, buy a complete set fot the unit and ones that are specifically guaranteed for it.
SOURCE: KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
SOURCE: dear sir... i have a
The key contacts are dirty on those keys. The contacts are conductive rubber "pills" in silicone domes that are pressed onto circuit traces an a board under the keys. One can clean these using ONLY 99% isoprophyl alcohol and Q Tips, HOWEVER: the disassembly to access the contacts is NOT for the inexperienced person. Each key has TWO contacts and one makes before the other and that is how they measure key velocity. When one contact fails, then maximum velocity usually results. You best take this to a repair shop and have all key contacts cleaned. DO NOT use normal contact cleaners as that will destroy the contacts.
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
