SOURCE: Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
SOURCE: Oven problem
microprocessor burned out? There was a problem of this with the double ovens, after the top oven went through a cleaning cycle.
SOURCE: dacor epicure electric oven
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
SOURCE: smeg single fan oven
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Hi Bill, did you ever get this addressed? We have the same problem. Thanks
