20 Most Recent
Dacor ECS127 Epicure Electric Single Oven Questions & Answers
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
What does "PRB 400 (degrees)"
PRB stands for Power relay board.
This is a bad error. This means that the power supply board had failed and needs replacement. The cost of replacement would be anywhere between $150 to $300.Unfortunately, this is not a DIY. You need to call a tech on site to replace the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
What does the F1 mean
Hi, the F1 error code means a problem with the System Watchdog Circuit..
Heating element won't heat.
Checked breaker,
It gets tricky from there...
I would check for power at the element....if there is power and the element is not getting hot then you have a bad element.... 220 volts across the two wires to the element or more is considered proper power...
If there is no power there.... then you need to flow the wires back till you get power and that is where your problem is....
This is the best way to troubleshoot your oven...but a good quality electrical meter is needed.... and you need to be very careful when working with electric as it can kill you!!!
heatman101
I don't know how to clean the oven
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
Oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
