Heating & Cooling Logo
J
Jay Patel Posted on Jun 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
AC was working fine until today...Fan is still working...Pulled the unit out and could feel the HEAT coming from the condenser. The whole unit was unusually hot..which is something I've never ran into as well!? What should I do now? Or is the answer still the same? No AC repair guys for PTAC's in my town. Already tried several...Please help! Sorry, about the confusion regarding PTAC model# from my last question.
Michael C
Level 2:
Novelist:
  • Expert 176 Answers
  • Posted on Jun 16, 2014
 Michael C
Expert
Level 2:
Novelist:
Answers
176
Questions
Helped
51857
Points
501
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
4 Related Answers
Anonymous
  • 26 Answers
  • Posted on Jan 25, 2008
SOURCE: ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Anonymous
  • 54 Answers
  • Posted on Jun 08, 2008
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Anonymous
  • 7 Answers
  • Posted on Dec 16, 2008
SOURCE: Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 27, 2010
SOURCE: GE Zoneline 1000 - heat stopped working this
Sorry to read about your problem, I hope this helps you out.
Sounds like you may a defective, reverse heat pump switch. If you were in Denver,Co I would be glad to work on it for you. They are no different than large units to work on.
and no, you cant work on the unit.....takes special tools
Just keep calling around for a person who will work on the unit..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
PTAC fan stalls when heat pump stops
Sounds like a bad motor module.
How long for the ac fan to start working? Ive noticed that the fan does not work when i turn the ac on, can this cause my car to overheat. I check the temp and coolant liquid both seems fine.
the ac fan starts as soon as the ac is switched on
the fan is provide cooling of the condenser before the radiator to prevent high head pressures in the ac compressor
it is the fan at the front of the car mand does not affect engine temp
there is a radiator fan between the engine and the radiator that will not start until the coolant temperature reaches a set temp at which point the ECM switches that fan on
if that fan is not working when the engine is hot , check for fan, coolant temperature sensor switch , fan relay, fuses or problem ECM
Condenser won't kick on, and is hot. Fan works? What's should I do?
Check whether the AC is on fan mode. There are two mode for this type. FAN and AC mode. Put it to AC mode and set the temperature. Solved!! :)
If it doesn't work, call the AC repair guy.
1) Either there will be error with the capacitor circuit which triggers the condenser.
2) there is an issue with your condenser and the circuit.
This is a small repair.
1helpful
My heater/ac fan sometimes won't work. What do I check first?
$24the AC light does not light until you turn the fan on, that is ok, the issue with your fan only working sometimes is more than likely a faulty blower motor, in some cases it is the switch, when the motor does not turn on try tapping it and see if that makes it work, if it does then it is the motor.
the switch at autozone is part number SW295 and is $16
the motor at autozone with the blower wheel is part number PM136
cost is $24
1helpful
My 1997 Honda Accord 4cyl. condenser fan began to run continuously (even after engine was shut off) after cycling the A/C temp. selector from hot to cold. I disconnect the condenser fan to avoid draining...
Sounds like the AC relay/switch is sticking on sometimes. Locate and swap this relay. Look at your fuse box lids for location or search online for the exact location. You also might have a leak in the ac lines or the AC condenser clutch is not engaging to kick the ac on. You should feel a slight power loss or hear a slight stutter in the engine when pressing your AC switch. This means everything kicked on. It's a millisecond before the ECU realizes this and kicks up the idle to compensate.
1helpful
2003 dodge ram 1500 w/ 5.7L hemi
you may want to check the fan for the AC condenser under the hood of the car. Your AC condenser should have a separate fan similar to that of the radiator. See if it turns on while the AC is on. If it does not, you may want to swap the relay of the two fans. If swapping the fan relay would start the AC fan then have the relay replaced. If it does not turn on then have the fan tested. Check the wires. If the fan is Ok you may have to check out the condenser if it needs cleaning.
2answers
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
2answers
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
