Sanyo DS31520 31" TV Logo
A
Anonymous Posted on Jun 15, 2014
Whats the sanyo tuhd1000 set top box remote control part number?
Need replacement remote control
4 Related Answers
Justin Smith
  • 135 Answers
  • Posted on Mar 25, 2008
SOURCE: replacement remote control
Hi there!
Try having it exchanged for another. May be a faulty remote. Also make sure the batteries are not flat. Otherwise may not be compatible as prescribed. Good Luck, Regards, JUS004
Jaime Hernandez
  • 2351 Answers
  • Posted on Jul 05, 2008
SOURCE: need remote for 2006 sanyo color flat screen tv
Great info AlmostBob.
Anonymous
  • Posted on Feb 12, 2009
SOURCE: programing remote control
Since you obtained a used TV, there probably wasn't an owner's manual with it. Here is the site where you can read and/or print the manual. http://www.sanyoservice.com/pdf/images/DS27510(OM)_excluded_French.pdf
On page 6 in the Quick Tips column, the second tip states: If the remote control does not work: Press TV key (see item 1).
Good luck resolving your problem.
Anonymous
  • 103 Answers
  • Posted on Apr 09, 2010
SOURCE: Need remote control settings for Sanyo television
In order to answer your question, I will need to know what type of remote you have. The code settings are different for almost every type of control. If you wish, you may repost the question with the remote manufacturer and model. Thanks for posting! sincerely, Der Strom
What is the code for a fizz creations remote pillow for a sanyo tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites http://remotesearch.blogspot.com/. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
NEED CODE FOR RCA REMOTE TO CONNECT TO SANYO SOUND BAR
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Need code for my Sanyo Remote GXBA FOR my Sanyo TV model # DP26746 Please....
What code do I need for my Sanyo tv using the Multi-brand tv remote 97P1R2BZ04
1helpful
Need code for a Sanyo fxre remote so it will work on my 32" Sanyo flat screen
I lost the remote control for my sanyo tv model number dp26640 and I need the pairing code compare Wi-Fi and Bluetooth products to my TV
I need dvd codes for Sanyo fxfr remote
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
What is the remote control code for a TV Sanyo Model #DS25204. It is a Sanyo remote control
0281,0229. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
2answers
I have a one for all remote I need the programing codes for a Sanyo tv
Universal remotes are normally pretty good. Search online for the codes for your tv's model no "Sanyo model blah remote code" or some all in ones ask u to turn device on only. And after it makes it go into standby you press a button quickly and that's the code learnt. You may find some Sanyo codes will do all your functions and some more basic codes will provide limited functionality. Hope that helps.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
