SOURCE: I cant make calls on my Kx-t7730 but i can recieve calls
sounds like you need to call a qualified tech
SOURCE: can a neighbor who has a similar digital cordless phone listen
It is possible. You gotcha try it out by carrying your cordless to neighbors hose and see if u can connect from there. If so get panasonic to change the frequency of your cordless........................sodeep
SOURCE: I HAVE A PANASONIC PHONE MODEL KX-TGA641C AND ALL
Remove all power (wall and batteries). Ensure that the phone line is active and properly connected. Did they used to work? If so, check line conditions. If not, return for exchange.
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
