SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
SOURCE: standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
SOURCE: Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
SOURCE: No Power to My Toshiba TDP-S8
Thank you very much for the precise answer!
Had the same fault but repaired mine.
As I only had a 1000u/16V at hand, I put it in instead the swollen 3300u/10V. It works as well.
BTW this cap was extremely hard to desolder, as its holes are very tight in the PCB.
some addition, how to take it apart: the only screw at the center of the bottom is obviously needs to be taken out, then only the plastic holds it in one piece. I used two credit cards (well, not credit cards, but magnetic hotel keys, but looks the same) to insert between the upper and lower chassis to separate them. The capacitor in question was on the bottom board, which has the power connector.
