SOURCE: seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
SOURCE: Seagate External Hard Drive powers down after being idle.
If you load the Free Agent Software, there is a utility for setting the power saving. You can set it to a number of different times including never. The default is 15 minutes. I think this is what you are experiencing. The settings are in the Utilities tab.
SOURCE: Seagate 500gb external hardrive cannot run after installed
yes , depending on which system you are using . this can be very easy. click on hard drive but dont open it right click go down to format and format it to ntfs . slow or quick format if nothing on.
SOURCE: Itunes messed up my external hardrive
See: http://www.fixya.com/PostAnswer.aspx?thid=3781106&prdid=512305
for a "duplicate" question.
SOURCE: I am trying to install seagate goflex free agent
Once the drive is connected to your current PC, inser your UBUNTU disk, as you go through the installation procedure it will scan available drives and ask you whether you want to automatically install or manually install to a drive of your choice.
You have to select the latter and install to your external HDD. If you choose the auto option you could wipe your internal HDD and the operating system ............. be careful.
