Williams-Sonoma Nespresso U Espresso Maker with Aeroccino Plus Automatic Milk Frother, Logo
A
Anonymous Posted on Jun 03, 2014
Why does my nespresso flashes 3 times stops flashes again
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
2answers
My nespresso stops half way though making a cup of coffee and have to press the button again repeatly to start it again
Has anyone operated your machine that was unfamiliar with the correct method. It sound as though the quantity has been reset. Try holding both buttons down while turning the machine on - hold till buttons stop flashing. This will reset to factory settings. Then, you can programme each button by holding it down whilst extracting, then releasing when the correct amount is extracted. It will remember this until you return the machine to its factory settings as above.
Hope this helps!
2answers
Nespresso magimix
Check the relay on circuit board
Why does My nespresso machine keeps on flashing 3 lights
Please see http://www.fixya.com/support/t14787831-nespresso_u_all_lights_flashing_pod for previous answer, or see troubleshooting at http://www.nespresso-us.com/media/product/PDF/38manual.pdf
Espresso and Longo buttons flash simultaneously and continuously
Try holding both buttons down while you turn the machine on until they stop flashing - usually about 5 seconds. This will reset the machine to its factory settings. Hope this helps.
45helpful
2answers
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
63helpful
6answers
After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Top Williams-Sonoma Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Williams-Sonoma Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
