SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: need a diagram for husqvarna model lth-130 mower deck belt
Here is a diagram I have found for you.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: How do I adjust the deck level on a Husqvarna
Not sure if you are looking for the nuts and knobs or how to level? Most newer decks have knobs for adjuctments. I park my mower on a concrete level surface make sure all tires are at the correct psi then with tape measure check front left and right at bottom of deck for same measurment. You can also put a 2 ft level on the deck and adjust.
