Where do i purchase a black wrist band for my kc3903
Please contact
[email protected]
thank you
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
SOURCE: Trying to replace battery in Kenneth Cole C275-04-KC3522
You need a watchmakers knife or caseback opening tool to open your watch.
1)If your watch has screwdown back, there should be grooves in caseback where you have to put in opener and unscrew that caseback.
2)If your watch has a 'clip-on' caseback, you have to carefuly examine the caseback and find the groove between caseback and watch case (it is called 'the lip'). This is the right point where to insert the blade of wtchmakers knife and open it using pressure and lever action.
3)The safest, but dearest way is to visit your nearest watch repair shop and ask for battery replacement. You may ask the watchmaker to show you how to do that, so, in future you can do that yourself.
Do not forget to rate, please.
SOURCE: Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
