20 Most Recent
Kenneth Cole KC3500 Wrist Watch Questions & Answers
Kenneth Cole KC3500 Chronograph
Pull your time adjustment knob out 2 clicks. hold down the chronograph time reset button and then press the start stop button and it will move to the next second. keep doing it until it is back at the 12 o'clock position.
HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Broken band
Yeh, just go to a watch repair shop and they will have the pin for your watch. If they don't, they are not a repair shop. Don't go to a jewelry store, they probibly won't have it. Look for a true watch repair shop in the phone book. Pins like that are in stock at any repair shop. Good Luck!!
Watch problem
The rotating number is beneth the dome crystal, you CANNOT repair by yourself, you can send it to 47-50 33rd St.
Geneva watch group
Attn: Tsai
I will help you with this problem.
Thanks
Tsai
