Was washing stopped f21 flashing unsrewed the bottom water came out still flashing f21
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at RepairClinic.com . They have helped me in the past, and they have parts too.
SOURCE: My washer stops in the middle and flashes F21?
Once I took the back panel off I then realized I had to take the front bottom panel off instead.
SOURCE: f 21 flashes
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
SOURCE: wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
SOURCE: The washer stops during the
F21 Long drain
Possible cause: Clogged filter, clogged/failed pump
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: washing machine stopped working and light is
Remove bottom panel, open the drain pump. You probably have something stucked inside the drain pump. Be carefull as there will be water flowing out if pump. If clearing objects doesnt solve the problem, then you might be dealing with a faulty pump
