Hello! I cant seem to get the elliptical to work. Every time I go to start a workout, within a few rotations, error 42 pops up on the screen. The incline is absurdly high, so I think that's part of the problem, but I can't seem to keep the elliptical going long enough for me to take the incline down. Help please!
The elliptical is actually version 5.17i. I inputted that into the question form but for some reason it must have switched back! The incline on the elliptical is so high that the wheels hit the front panel.The elliptical is actually version 5.17i. I inputted that into the question form but for some reason it must have switched back! The incline on the elliptical is so high that the wheels hit the front panel.
You can't post conmments that contain an email address.
Precor Error Code 42
Error Code: 42
Manufacturer: Precor
Model: All Models
Error Description:
Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40.
Possible Reason:
Bad or intermittent connection in the lift motor controller.
The lift motor requires calibration.
The lift motor potentiometer is bad.
The lower PCA to upper PCA cable is bad.
The lower PCA is bad.
The upper PCA is bad.
Recommended Action:
Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
1.Elliptical machines have become more and more popular in gyms around the world (as well as at private homes). You can find them next to the treadmills and bikes in almost every gym. These machines, also known as cross-trainers, have quite a few benefits. First of all, elliptical machines provide a "no-impact" workout,which takes stress of your knees, hips, and joints. When I started running on the treadmill, I quickly began to have pain in my knees. Once I moved to the elliptical machines, the pain was gone. Second, elliptical machines include upper body moving handles, so you can train your upper body as well. Moreover, whileworking out with elliptical machines you use many muscle groups such as the quads, glutes, chest, hamstring, triceps, and biceps. Last, most elliptical machines come with programmable workouts that mimic real-life activities such as hill climbing. In conclusion, elliptical machines are great for burningcalories, getting challenging workouts, and protecting your body from unnecessary stress.
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Whereasa treadmill provides an "impact" workout, elliptical machines provide a "no-impact" workout. This makes workouts on the elliptical trainerhave much less stress on the knees, hips, and joints.
If
a cardiovascular workout is what you want, you should get an elliptical
machine. They give you a total body
workout - with handle bars for your arms and pedals for your feet. You can burn a lot of calories without having
a lot of heavy impact on your joints.
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Lift Position Value Out of Range Precor Error 42
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
