I want to install window 7 while there is windows 8 already installed, the bios setup just showing window boot manager in the boot device preority how can i make the CD Rom first boot able device.
If someone need windows key that i suggest you go site www.vinhugo.com to got. My key got here and after i used is great works, Hope can help you.
Since Windows 8 uses Secureboot and express cache which makes it difficult to boot external media.
http://forum.notebookreview.com/samsung/701927-clean-install-windows-7-8-samsung-7-series-chronos-laptops-expresscache.html
SOURCE: Toshiba Satellite A215-S5849 Laptop -
take out the battery and ac adapter for 5 minutes, hold down the power button for 60 seconds, plug back in the ac adapter and turn on, try entering the bios.
if the problem remains and since you are unable to boot from any device, you would either have to send this laptop to a repairer, or remove the hard drive from the laptop, use a adapter to connect it to a desktop machine or to another laptop and begin the windows setup on another machine, or install windows on another machine (may cause a blue screen when switched to another machine)
or make the hard drive bootable, copy windows setup files into the drive and install from the drive.
SOURCE: I can't load flash drive which contains bootable
i would assume you made the flash drive bootable and did not just copy windows onto it,,
if you didnt make the flash drive bootable it simply wont work
go here for more info
SOURCE: Samsung mini laptop n148. Windows
It sounds to me that unfortunately you have an error on your recorded CD and there will be nothing you can do to repair that.
The installation of Norton should not cause the problem itself an error on the hard drive will usually cause that problem.
SOURCE: i want to download PIXMA MP270 series and setup
you can download from the link below:-
http://software.canon-europe.com/products/0010753.asp
plz do rate the solution if got help
SOURCE: My Samsung R530 won't boot, just shows blue
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
