SanDisk Sansa e250 MP3 Player Logo
Posted on Nov 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansa e250 freezes!
When i turn my player on it freezes on the sandisk screen.ive tried reseting it many times but nothing seems to work?
  • jazzyjas Dec 13, 2007
    ok so when i tried to put a video on my mp3 it worked fine. when i restarted it says "refreshing database" but it never loads completly.Then the screen turns black but it doesnt turn off. I have a 2 year warranty but i dont know if im supposed to take the mp3 player with all the things it came with because the headphones broke and i threw away the box. All i have is the mp3 player, the charger, and the receipt
Anonymous
Level 3:
  • Master 626 Answers
  • Posted on Nov 05, 2007
Anonymous
Master
Level 3:
Answers
626
Questions
0
Helped
369146
Points
1382
This should take care of it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Sansa freezes
try inserting a microSD card when player is turned off then put it on...work most of the times...
Sansa e250 Freezing
Reset the player, then get the Sansa Recovery Tool from Sandisk's website
My sansa wont let me always shuts off
The cleanest way is to start from scratch. Format the drive and reload.
2answers
Screen black
Try to get a firmware upgrade done..once you have that done you should be able to use the device without having any problems..
My sansa froze
Try to remove the battery and force the machine to switch itself off
3answers
Broken
Try to reset it- hold down the power button for about twenty seconds. http://sandisk.com/Retail/Default.aspx?CatID=1532 The tool you can download at the above link will supposedly reset the machine to its factory condition; note that any data on the device will be lost.
2helpful
5answers
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
6helpful
9answers
Sandisk e250 mp3 player froze up and won't turn off!
To Reboot your sansa e250 without removing batteries . Switch to hold position ( right beside headphone jack ) Press and hold menu and rec buttons at the same time untill screen resets. On my player lock up usually happens when it hits a corrupt song - try to delete and reload the culprit to minimize future lock ups. Hope this helps someone out there.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
