Bose Acoustimass 10 III System Logo
N
Nanda Posted on May 25, 2014
Bose rj45 input pinouts - Bose Acoustimass 10 III System
BOSE PS28 I. There is a RJ45 media import on that, is this possible to make a RCA connection for it? If anyone have any idea about pin out of that, it will be great for me. Thanks
Question edited for clarity.
Facing the 8 pin male plug with two pins on the bottom and three on the top, count pins 1-8 left to right and bottom to top (pin 1 in the lower left and pin 8 in the top right). This is the inverted view from the female layout.
On the RJ45 is, of course, 1-8 left to right with tab down and end facing away from you.
RJ45 pin1 = male 8 pin7 = data (left pair white conductor)
RJ45 pin2 = male 8 pin5&8 = ground (left pair drain common at male 8 end)
RJ45 pin3 = N/A
RJ45 pin4 = N/A
RJ45 pin5 = male 8 pin5&8 = "audio" reference ground (right pair drain common at male 8 end)
RJ45 pin6 = NA
RJ45 pin7 = male 8 pin1 (right pair white conductor) = SPDIF 0
RJ45 pin8 = male 8 pin2 (right pair red conductor) = SPDIF 1
I am not sure of the polarity for the SPDIF because Bose only documents 0 and 1.
Was from here
https://www.remotecentral.com/cgi-bin/mboard/rc-custom/thread.cgi?13855
More here
https://www.google.com/search?q=BOSE+ps28+pin+outs
2helpful
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
Bose lifestyle 38 pinout diagram 8 pin Din to RJ45
Hi, HELP!
can someone know the wiring of Bose Lifestyle 18/28/.... Link cable?
8-pin Mini din to RJ45
something like in my picture below, but not this one as it is a 6 pin only...
but the principle is good, number 1 here goes to number 1 there, etc...
Many thx!
Wiring diagram cat5e wall plate
Google"RJ45 pinouts".There is some sight I found(free)that has connector pinouts for all kinds of stuff.There are several different ways to configure an RJ45(8 pin)jack,depending on the application.
3helpful
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
1helpful
2answers
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
1helpful
Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
1helpful
2answers
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
