Tappan TGF320 Gas Kitchen Range Logo
Pam VonPressentin Posted on May 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to light the oven - Tappan TGF320 Gas Kitchen Range
Raymond Richards
Level 3:
Master:
  • Master 407 Answers
  • Posted on May 25, 2014
Raymond Richards
Master
Level 3:
Master:
Answers
407
Questions
0
Helped
101110
Points
1345
It depend on if it has an electric genitor of a pilot light.
Lighting pilot light on Magic Chef oven: CGS3760ADC
since it is piotless how did you light burner pilots? The oven is piotless and does not have a free standing pilot. here is a link to manual copy and paste page 18 deals with oven.
piotless
How do you light your pilot light on an kenmore oven
To light the pilot light on a Kenmore Maxitrol oven, please follow these steps:
  1. Locate the pilot light assembly. It's usually at the bottom of the oven, behind a small metal cover.
  2. Turn the oven control knob to the "off" position.
  3. Remove the metal cover by pulling it out or lifting it up, depending on the model.
  4. Locate the pilot light and the pilot light valve. The valve is usually a small red button located near the pilot light.
  5. Press and hold the pilot light valve in for a few seconds while you use a long match or lighter to light the pilot light.
  6. Once the pilot light is lit, continue holding the pilot light valve in for another 30 seconds.
  7. Release the pilot light valve and make sure the pilot light stays lit. If it doesn't, repeat the process.
  8. Replace the metal cover and turn the oven control knob to the desired temperature setting.
Note: If you're having trouble lighting the pilot light or keeping it lit, it may be best
Why won't my oven light turn off?
Hi MICHAEL.
Possible Cause: Unseated Door. If the oven door does not connect with the door light switch, the oven light will stay on. To test, open the oven door and press the door light switch. ... Disconnect the ovenfrom the power and turn off the gas.
Oven Light Won't Turn Off - It Is Fixed Appliance Repair ' (404) 407-0071
OR TRY THIS LINK.
https://www.google.com/search?q=oven+light+wont+turn+off&rlz=1C1AVFC_enGB797GB798&oq=oven+light+wont+turn+off&aqs=chrome..69i57j0l5.4862j0j9&sourceid=chrome&ie=UTF-8
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 • AEG Ovens
The bottom oven light and heat is on all the time can shut off
Faulty switch if Oven light has a switch, some ovens light stays on, some oven lights switch.off when door closed. As to Oven being on all time , Faulty Switch.
Mar 13, 2015 • Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
1helpful
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Top Tappan Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
