20 Most Recent Tappan TGF320 Gas Kitchen Range Questions & Answers
If you live in Huntington Beach, CA and need appliance repair service call us at (714) 698 88 73 or visit our website Appliance Repair Huntington Beach CA 714 698 88 73
Tappan TGF320... | Answered on Sep 03, 2017
Did you give it time to cool down? If so, probably a control issue.
Tappan TGF320... | Answered on Sep 01, 2017
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Tappan TGF320... | Answered on Jan 27, 2016
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Tappan TGF320... | Answered on Jun 19, 2015
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Tappan TGF320... | Answered on Oct 29, 2014
You probably will need an open-end wrench the right size to fit it.
Tappan TGF320... | Answered on Jul 12, 2014
The igniter is extremely brittle after it has been used. Often times when it fails a small hair line crack can be seen upon physical examination. Although it would appear that contact is still being made, it will not glow and reach the temperature needed for the gas valve to be opened. An Ohms meeter can be used across the two leads after it is removed form circuit I would expect less then 1 ohm on a good one but because even a bad one my be making contact when it is cold as soon as a bad one is energized the gap will open and Ohms will be increased that could not be measured. Just look for a crack, use your finger nail if you feel one it is bad.
Tappan TGF320... | Answered on May 31, 2014
After the self cleaning process you might see i wight powdery residue. This can be cleansed out with a damp cloth. No chemicals should be needed. If you use household cleaners you may have some odore when you use your oven so I would just use a damp cloth.
it depend on if it has an electric genitor of a pilot light.
Tappan TGF320... | Answered on May 25, 2014
probably a bad controller or relay, get it fixed or replaced.
Tappan TGF320... | Answered on Mar 26, 2014
Tappan TGF320 Gas Kitchen Range Logo
Popular Tags
299 questions posted
Top Tappan Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Tappan Kitchen Ranges
Most Popular Question
tappan self cleaning oven clean itself
  • Kitchen Ranges
