Wahl magic clip clippers are very noisy , tried to adjust ?
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
