Hi i had the same problem and did exactly as u instructed but its not working. I checked the filters hundred times but there s not a speck of dirt visible. What can it be?
Have you checked freon pressure ? There is a clutch relay and the low pressure switch in the circuit. There is also a master controller in the circuit that handles the compressor and blower along with the blend doors. The wiring diagram I have is too large to post here.
If the filter was removed and replaced while the unit was ON, it doesn't sense that it was replaced or cleaned. Turn the Master ON/OFF Switch to OFF, unlpug it from the wall, remove the filter and reinstall it properly. Then, plug the cord back in and turn the Master ON/OFF Switch to ON. The Clean Filter indicator light, should have stopped blinking or will shortly there after.
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
hi guys i found reset button in whirlpool chrome model split 1.5 ton just you lift the door of ac then you look carefully at the top of right there is a warnig door no need open that just above a button like thing in a hole just press it when ac is on
Open the front Panel, On the extreme right hand side there is a white colour button, press it hard for 2 minutes, make sure your AC power it switch on, the clean filter light will disappear. Do this only after cleaning, drying and reinstalling your filer net. Regards Vipul Prasad
