OEM Zboost Yx545 Soho Dual-band Signal Booster Logo
b
bruin serice inc Posted on May 20, 2014
Yx545 worked well for a week now light stays green no signal
At&t 3g micro cell works
lstofa_fs
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 15, 2014
lstofa_fs
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
432
Points
This may work try unplugging and then rebooting if that doesn't work check your manual for a reset feature you may have these already but sometimes we miss these small things hope this helps
2answers
I hone signal
There are several signal boosters available on line. They all run about $400.00. If you have good internet you can also get a micro cell from your carrier that connects to the internet so you can use your phone.
Feb 02, 2018 • Cell Phones
Why did my yx545 zboost work within a week thelight stays green no signal !
The quick setup indicates that a steady green light means that it is ready, and there is no activity. A flashing green light means there is activity. That's all the further I can troubleshoot with you without knowing how you have it set up. If you continue to have issues, contact zBoost at [email protected] or 1-800-871-1612. They will be able to troubleshoot much better. If it turns out to be an issue with the device, it does come with a 1-year warranty, so they will be able to replace it. Customer Support
2g singnal on work GPRS signal only. EDGE signal not working?
http://download.cnet.com/Signal-Booster-2G-3G-4G-WiFi/3000-10440_4-75915581.html
http://www.youtube.com/watch?v=1kAgFToDVqg
1999 jimmy no dash light and signal indicators on
Usually a ground problem - - the lights that are on are grounding thru the cluster.
Why is it that in the last 2 weeks, sometimes the car starter works and sometimes it doesn't?? It cant be the battery cuz it shows a green light PLUS I tried using my 2nd one (extra remote) and I have the...
the problem sounds like it is how the starter works. It starts and afte a few seconds it does a system check to see if the car started and if works right it will continue to leave the car on and if not it trys 2 more times to start and stay on. Most techs use voltage sense or a virtual tach signal to do the system check. I have found that the best way to have the starter work and stay on is by hooking up the tach signal and making sure the options are set for system check ON and Tach signal check on.
1helpful
My Samsung M510 got really wet, i took it apart
my samsung shows half white screen,top half plus freezes on certain screen & shows static.Can u tell me whats wrong with it as im not sure if its a battery error or malfunction??
3answers
Inactive usim" comes up when i put my 02 sim card in my ku990 lg phone, why is this
You need to go to a phone shop that stocks 3G sims. Get a $10 sim (a blank free one probably will not work). You didn't say whether you were on a pre-paid sim or a plan. Anyway call 3G and ask them activate it. Get the number off the sim before you ring them. They will need U to quote that. hope it helps :o)
1helpful
2answers
3g connecton - AT&T service - I keep getting
first, check the 3G led is on, if is on, then open the 3g connection mamager and wait about 1 minute, if doent appear signal, download the lastest drivers of 3G Modem and the updated 3g connection manager here: http://support.acer-euro.com/drivers/notebook/as_one_150.html
Lost signal
you can try to change the network settings.
put it in GSM Mode.. not 3G.
or change your band.
Top OEM Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an OEM Cell Phone Expert? Answer questions, earn points and help others
