20 Most Recent DEI Python 1400XP Remote Start/Keyless Entry System Questions & Answers
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer...
rest is up to u.. U can also get free manuals
DEI Python... | Answered on Jan 24, 2019
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
DEI Python... | Answered on Jan 23, 2019
The automated lighting has ambient light sensors and an electronics package that can cause similar issues when they fail.
DEI Python... | Answered on Feb 03, 2018
Properly installed remote starters rarely interfere with normal operation of a vehicle. There can sometimes be an issue with the security module that interfaces with the vehicle anti theft. Although rare it can be diagnosed easily. Most often is the vehicle security system components found to be degrading overtime causing intermittent issues. Passlock, passkey 123, pats, all have their own unique component failure issues.
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
DEI Python... | Answered on Sep 15, 2017
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
DEI Python... | Answered on Feb 07, 2015
At this point in my life, I don't know what I would do with out my car remote. It should be an auto electrician that installs the system. As for the program, I am not sure. You might need to look further into it.
Elisa Jed ' http://www.stevemacautoelectrics.com.au/services
DEI Python... | Answered on Jul 16, 2014
It sounds like the alternator is bad. Remove it and have it tested before replacing the battery.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
DEI Python... | Answered on May 27, 2014
the problem is in the connections with the unit to the car. check all wires make sure tight and connected. if no problem then let me know.
DEI Python... | Answered on May 08, 2014
Tools: 10mm torque wrench
Step 1: Find the release bonnet lever or button in the car.
Step 2: once the bonnet is open, locate the battery pack.
Step 3: Then locate the negative charge and unplug the connector to the terminal by using your torque wrench.
Step 4: Then replug it in and close Start the car up and it should work.
Hopefully it works.
DEI Python... | Answered on Jan 19, 2014
go back to installer for reset guidlines
DEI Python... | Answered on Dec 21, 2013
Here is the link for Python 1400XP Wireing!
http://rovertech.clanteam.com/depo/Python/1400xp_install.pdf
DEI Python... | Answered on Dec 04, 2013
Year/make/model? Have you checked the reading from your intake air temperature sensor (IAT)?
DEI Python... | Answered on Nov 09, 2013
Sounds like the bypass that was installed when the remote start was done lost programming, if you look under the dash and find some boxes under there reply back with some part #'s and I am sure someone can help you out.
DEI Python... | Answered on Nov 04, 2013
The way I understand your question is your vehicle main computer has been replaced and it is not working properly. Since you say you cannot start it, have them come and get it and do what ever additional programming is required. You cannot do this yourself. If this is a remote start issue and you can start your car with the key, take it back and have them make necessary repairs.
Thanks for your interest in FixYa.com.
DEI Python... | Answered on Jul 04, 2013
DEI Python 1400XP Remote Start/Keyless Entry System Logo
97 questions posted
Top Directed Electronics Vehicle Parts & Accessories Experts
Joaquim Martins
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Directed Electronics Vehicle Parts & Accessories
Most Popular Question
need wiring
  • Vehicle Parts & Accessories
