Pride Jazzy 614 Hd JAZZY 614HD Logo
A
Anonymous Posted on May 17, 2014
Why when charging battery seems to drain instead
Battery new but drains during charging
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Feb 24, 2015
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2700587
Points
29284
The 3rd wore of the charger plug tells the controller to shut off all power to the scooter while the charger is on. Check the plug for a broken wire
3answers
I have just replaced my old battery in my 1995 Chevy Lumina and now the new one seems to dicharge completely over night and sometime even sooner. What could be the problem?
Could just be a bad battery.
I used to work at an auto parts store, and every once in a while we'd find a brand new battery that simply wouldn't hold a charge.
Had this happen to myself just this past fall. Bought a new battery, within about 3 days, the battery light started coming on. Brought the car back to the service center, and sure enough, they came out and told me the battery would not hold a charge, and needed to be exchanged.
Even a brand new battery does not mean that the battery is good.
Take it back to wherever you got it and have them test it. They can tell you if the battery is any good or not, and whether it's the battery or if it's the alternator.
Battery completely drained after 45 mins of listening to cd player without car running,
a healthy battery will take a charge and discharge and be o k -you have several things going on-the ticking noise is some kinda rely that is turning on and off probably because of low voltage-the voltage jumping around sound like the alternator is giving up and is not fully charging battery-you may also have a drain on the battery that doesn't stop when you turn the key off like an extra power amp for the radio- you can take your car to autozone or advanced auto and they will check out the charging system for free and tell you what is going on-cheers Denny
1helpful
Mitsubishi Diamante 2002 - slow battery drain when not running.
This problem may be a drain or a bad battery or alternator.
The first thing to do before going on trying to find the system that is draining the battery would be to have the battery tested and charging system tested.
A weak battery will seem ok after the car is jumped or will barely start the car and the alternator will charge it even though the alternator is overworking due to weak battery and during the day or when car does not sit long it will seem ok. then when car sits overnight or a few days battery will weaken on its own, making it look like a drain,
so first step is battery test and alternator/charging system test.
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
The charging base is loose you have to replace.
It will work.
3helpful
How long should u charge battery first time and can u over charge
this depends on the battery size, you normally should be ok after 3 hours or so
batteries get to max chargig capacity after about 3 full charges (+ fully drained)
Normally you cannot overcharge, but you can make your battery lazy if you never let it drain and always charge it during work it will get lazy.
So Try to drain your battery frequently, and do not work with te charger connected all the time
01 Suburban battery draining
take it to an autosparky ......They will check to see if there is a drain on the battery.
cheapest and fastest option.
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Batteries draining problem?
this problem can be caused by many factors. Use of the phone can drain battery life for example if you use the phone for browsing the web or as an mp3 player, even to make or recieve calls the battery life will not be as long as it would if just on standby. also if the battery hasn't been conditioned or is being over charged this can also lead to short battery life.To resolve the problem try conditioning th battery, basically let the charge drain completely out of the phone until the phone actually switches off, then charge the phone for 24 hours. Next time the battery goes ded only charge for the recommended charging time (this info can be found either in your phone user guide or by contacting the customer service department of your network provider).
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
