20 Most Recent Garmin StreetPilot c550 GPS Receiver Questions & Answers
Does it work properly otherwise? Is this the only place it gets stuck?
Garmin... | Answered on Jan 13, 2017
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Garmin... | Answered on Apr 12, 2016
The C550 does support USB 2.0 so data transfer of the Maps was most likely faster. The newer USB drivers from Garmin is most likely USB 2.0 compliant. Perhaps they didn't fully test it for USB 1.1 Anyway it's working for now. Usually I go to setting Map, Map info to verify that the upgrade was successful.
Return the unit to the pawn shop. This is a PIN put in by the original user just in case it gets stolen. If the original user sold this to the pawn shop they would of removed the PIN or provided it to the pawn broker. If it was stolen there is nothing you can do but throw the unit out if the pawn broker will not help.
Cheers
Jesse GPS City
Garmin... | Answered on Oct 02, 2014
If you can send it in to Garmin to have it unlocked, then there must be a "master" code. Since the USB port is dead until the unit is unlocked, Garmin must have to either enter in some special code or reset the unit in some special way.
Garmin... | Answered on Aug 10, 2014
i forgot my pin number/ how can i get one
Garmin... | Answered on May 20, 2014
Check the battery contact points inside the unit. There may be a thin film of crud (oxidation) that prevents contact, especially if the previous battery had any signs of corrosion.
Garmin... | Answered on Jul 07, 2013
Not without the unit being unlocked by having the correct PIN entered, or the unit being taken to the Security Location (the location at which the PIN was initially set). If you purchase it and send it to Garmin to be unlocked (which they can do for a fee), they will require proof of purchase or they will not return the unit to you. You might be better off avoiding that particular GPS.
Garmin... | Answered on Jun 13, 2013
Maybe Transport it to my phone than tell me
Garmin... | Answered on Sep 14, 2012
Garmin StreetPilot c550 GPS Receiver Logo
362 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
StreetPilot Garmin
  • StreetPilot Garmin
Most Popular Question
download maps
  • GPS
