How do I get power to my stereo?? It doesn't have enough power to pump out sound.
My lgdvt418 is 10 years old. It seems there isn't enough juice to put out sound. Shows that the unit is on. But no sound. It's been doing this for last few months. Turn the volume up to 11 out of 40 and it used to kick on. Put below that mark after it started working and sound cuts out. Now it won't even do that. How can I fix this and not have to for over $$$ for an entirely new system???
Sounds like you have a brake backing plate (or something similar) rubbing the brake rotor, or up against the tire or wheel. I would look at that first. It is very likely not the power steering or the pump or belt. You are saying that the chirp is less when steering to the right. Look at the Right front wheel and wheel bearing.
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
you may need a new battery. your clicking noise may be the ipod recycling because the battery doesn;t have enough juice to run it. it has no hard drive so the clicking isn;t coming from that. get a new battery
