Cant get the steam to start I get a big steam wooch from the grinder section ?
If you've used the machine for awhile, and you have not cleaned/descaled it, it may be clogged with mineral deposits. Citric acid, a white natural mild acid is a good descaler. It comes in powder form and readily dissolves in water. You can locate citric acid on the web (ebay). White vinegar also works, about 1/2 & 1/2 with water. Run the solution through the machine to descale it. It may take a few treatments to get all the mineral deposits out. Use about 2 tbsp of baking soda in water afterwards to neutralize the acid.Hope this Helps!!
