SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
SOURCE: Refrigerator not working, freezer is fine
You can get the step by step instructions (lots of pictures of each step) to repair this exact problem at:
www.AnyoneCanFixIt.com (specifically at http://www.anyonecanfixit.com/household.htm scroll down towards the bottom to look for Warm Refrigerator and Cold Freezer repair). It will save you a lot of money to do it yourself!
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
SOURCE: Maytag refrigerator with freezer on bottom
Sounds like the defrost timer.Located by cold control.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
