Rival 18 Qt Roaster Oven with Buffet Server Logo
A
Anonymous Posted on May 07, 2014
How do I cook pinto beans in a roaster oven? - Rival 18 Qt Roaster Oven with Buffet Server
Karen G
Level 1:
Habit-Forming:
New Friend:
  • Contributor 6 Answers
  • Posted on Jun 03, 2014
Karen G
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
6
Questions
0
Helped
23465
Points
11
Soak beans overnight in cold water, drain and rinse, place in roaster (adding a ham bone is a good seasoner), add salt (about 3/4 Tablespoon), cover with water, turn roaster on to 350 degrees, add hot liquid or ham juice when beans are going dry and stir. Don't check too often, because it will release heat and slow cooking time down. Takes 5 hours to fully cook. (Note: bean pkg has quick soak method which works in place of the overnigt soak)
1 Related Answer
Karen G
  • 6 Answers
  • Posted on Oct 12, 2011
SOURCE: how to cook pinto beans in my 22 quart roaster
I cook 140 lbs of beans every year at church for a ham & bean dinner. I soak them overnight in 4 large rubbermaid containers (about 35 lbs in each covered all the way to the top with cold water). In the morning I drain the water, rinse beans and divide between about 14 cookers (several of them are the 22 qt roasters). You can put beans in to about 1 1/2 to 2" of the top rim. Put a ham bone in (I pre-cook about 12 10 lb bone-in hams two to a roaster sitting in about 1" water several days before, chop the meat, save the juice and the bones) and a cupped palm full of salt (3/4 to 1 T ?) and cover with water. Cook on about 350 degrees. When they start going dry add the leftover ham drippings that were saved (I usually have it heating in a crockpot nearby so that it doesn't slow the cooking of the beans down).
How many dry pinto beans can you cook in 17 quart electric roaster
1 cup of dry pinto beans plus 2 cups of broth or other liquid = 6 cups of cooked beans.
1 Quart = 4 cups so, a 17 Quart cooker would hold 68 cups of cooked beans (including liquid), to the brim.
11 cups dried beans = 66 cups cooked. I recommend:
10 cups dry beans + 20 cups liquid = 60 cups cooked beans
2answers
How to cook pinto beans
Just the same way as any other bean.
Dec 24, 2017 • Cooking
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
9helpful
How to cook pinto beans in my 22 quart roaster oven
8helpful
Do you put water in the base of a nesco roaster?
No, you specifically DO NOT put water in the base between the roaster and the cook pan, this actually interferes with cooking.
1helpful
Do you have to put water in the first pan to cook a turkey?
Absolutely not. This is an oven, not a steam table, and water in the main roaster actually interferes with heat transfer. Water in the roaster cooking pan (the inside pan) actually steams the turkey, not a yummy solution.
Top Rival Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
