20 Most Recent Rival RC61 6-Cup Rice Cooker Questions & Answers
2answers
Completely stopped working. Plugged it in and the
Had mine 3 months and mine has done the same thing THREE times. ...with THREE different cookers!
12/12/2023 1:31:12 PM • Rival RC61 6-Cup... • Answered on Dec 12, 2023
2answers
Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
1/27/2021 8:08:25 AM • Rival RC61 6-Cup... • Answered on Jan 27, 2021
4answers
No instrution manual
You are an *******....Just to be blunt....This person is asking how to cook the rice to water ration in the rival 6 cup rice cooker and that ratio is like other ways to cook rice, which you are completely wrong about maybe you should take some lessons on how to cook. Its 1 PART RICE TO 2 PARTS WATER....NOT EQUAL, and in the cooker its 2 cups rice and 4 cups water makes a perfect pot!
12/14/2016 2:39:34 AM • Rival RC61 6-Cup... • Answered on Dec 14, 2016
I have a Rival 6 cup rice cooker RC61 the diode is
Diode?
u must've mean THERMAL cut off fuse?
The fuse cut off power to HEAT up ur rice cooker, changing it w/ the same temp code will fix ur rice cooker!
6/4/2015 3:43:08 AM • Rival RC61 6-Cup... • Answered on Jun 04, 2015
2answers
Rival rice cooker stopped working
Mine just did as well today. Thought I blew a fuse, but no, just not working, although it did finish the pot of rice.
4/22/2014 3:46:14 AM • Rival RC61 6-Cup... • Answered on Apr 22, 2014
2answers
I LOST THE MANUEL FOR
Your manual for the Rival Automatic Steamer/Rice Cooker 4450 is available from here:
http://micromatikal.dlinkddns.com:8000/cust/4450.pdf
Sorry someone has not responded sooner.
3/17/2014 3:05:07 AM • Rival RC61 6-Cup... • Answered on Mar 17, 2014
0answers
Rival 6-cup rice cooker does not work
I have had THREE different cookers over the past year and ALL THREE have done the exact same thing. It has to be electrical and I suspect it blows an internal fuse...then it is no longer working. This is awful. I would never recomend it to anyone.
1/1/2013 12:45:05 AM • Rival RC61 6-Cup... • Answered on Jan 01, 2013
5answers
I lost the measuring cup for the cooker
Measuring cup.
Done!
10/7/2012 3:28:09 AM • Rival RC61 6-Cup... • Answered on Oct 07, 2012
2answers
Rice cooker lid replacement?
if you still have the reciept the best thing that i would suggest is to take it back to the store or call the manufacturer and they will send you out another under warranty cause there should be a 1 year warranty on the unit.
10/14/2011 12:10:48 AM • Rival RC61 6-Cup... • Answered on Oct 14, 2011
I have acquired a rival
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
9/24/2011 10:56:32 PM • Rival RC61 6-Cup... • Answered on Sep 24, 2011
I have purchased a 6
Hi there.
You can download Owner's manual at http://www.rivalproducts.com
Regards.
9/7/2011 1:27:07 AM • Rival RC61 6-Cup... • Answered on Sep 07, 2011
Where can I get a
Hi there.
You can check for the nearest authorized service and parts provider in your area by visiting http://www.rivalproducts.com
7/8/2011 2:58:02 AM • Rival RC61 6-Cup... • Answered on Jul 08, 2011
My Rival RC61 rice cooker
The Owner's Guide for your Rival RC61-CN 6-Cup Rice Cooker can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RC61_43_53194273.PDF
3/28/2011 7:23:37 AM • Rival RC61 6-Cup... • Answered on Mar 28, 2011
Rival RC61 6-Cup Rice Cooker Logo
57 questions posted
Top Rival Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Rival Kitchen Appliances - Others
Most Popular Question
  • Kitchen Appliances - Others
